Message 1 of 11
BT Smarthub
Can anybody help me? When I visit my smarthub interface at 192.168.1.254 the connection is always insecure, ie not https. Have I been hit with a SSL Strip attack? What is to stop a hacker from harvesting my wireless key and admin passwords every time I change them?
10 REPLIES 10
Message 2 of 11
Re: BT Smarthub
Hackers have got to get into your LAN in the first place.
Message 3 of 11
Re: BT Smarthub
If you unplug your Smarthub from phone socket you will still be able to access it via 192.168.1.254 because you are accessing it on you own local network not via the Internet.
Message 4 of 11
Re: BT Smarthub
thanks for the advice. That is a practical solution I can unplug it and so I won't be on the internet
Message 5 of 11
Re: BT Smarthub
thank you for the reply. I am studying pentesting but I don't know much about it yet. I thought that an insecure connection would mean that somebody on the outside of my PAN could sniff my passwords
Message 6 of 11
Re: BT Smarthub
No that is not what I was advising. I was trying to point out that even if you did do that you would still be able to access it. That is because you are not going through the Internet when you are accessing it, ie it is safe and secure.
Message 7 of 11
Re: BT Smarthub
so are you saying that although the admin interface is not over a secure connection it is not possible for somebody to sniff the passwords?
Message 8 of 11
Re: BT Smarthub
For somebody to sniff your passwords they would need to be connected to your LAN. I.e they would need the wireless password to get the wireless password!
Message 9 of 11
Re: BT Smarthub
That is correct. All you are doing is accessing the page that is held within the Smarthub's software. It is not going via the Internet hence the reason you could access it even if you were disconnected from the Internet.
Message 10 of 11
Re: BT Smarthub
Thank you for your advice. That is very helpful.
