heenebeach
Message 1 of 7
BT TV box
Can I install a BT TV box when I have a TV booster?
6 REPLIES 6
Anonymous
Not applicable
Message 2 of 7
Re: BT TV box
What do you mean by TV Booster?
heenebeach
Message 3 of 7
Re: BT TV box
It's a device that boosts the signal into the TV; specifically a Nikkai Distribution Amp 2 way.
Anonymous
Not applicable
Message 4 of 7
Re: BT TV box
Yes but if signal strength gets near to 100% then you'll lose the Freeview HD channels. Yes I know what you're thinking but I'm stone cold sober
heenebeach
Message 5 of 7
Re: BT TV box
Thank you for that information
TimCurtis
Recognised Expert
Message 6 of 7
Re: BT TV box
@Anonymous
Don't understand your comment about losing the HD channels when the signal strength approaches 100%.
The most likely outcome of a high signal strength is picture breakup, I've never heard of it causing channels to be lost.
I run at about 95% signal strength which I find to be just right.
Anonymous
Not applicable
Message 7 of 7
Re: BT TV box
Hi Tim.
I'm surprised to hear you don't understand that bit, there are many posts on the community regarding it, particularly with the T2100 box. The standard fix seems to be fitting an in line attenuator in the aerial lead
It's not just a case of pixelation, the HD channels completely disappear from the EPG
