1962glasses
Message 1 of 4
BT Verve 450 question
Can you transfer calls between two Verve 450?  If so how do you do it, please?
3 REPLIES 3
NeilO
Moderator
Moderator
Message 2 of 4
Re: BT Verve 450 question
Hi @1962glasses welcome to the community and thanks for posting your question, yes that's possible, page 65 of the user manual explains how you can transfer an external call between two Verve 450 handsets.
1962glasses
Message 3 of 4
Thank you Neil0
I'll try that in a minute. Hope it will work as I have two master stations in the system rather than one master and one used as a charger.
Here we go!
Thanks again
NeilO
Moderator
Moderator
Message 4 of 4
@1962glasses I don't think that will work if you're using two master stations as they wouldn't be linked.
