JK07749423528
Message 1 of 6
BT Voyager 1010 USB Adapter Driver
Hi folks,
I was digging around some old boxes in the attic and found a Voyager USB 1010 Adapter. I know its the  type of tech that Moses used to build the ark but I am curious to see if it still works. there is no Driver CD with it and I am struggling to find anywhere online that has the Driver for it. Can any one point me in the right direction?
Thanks in advance
JK
5 REPLIES 5
Devon_Dave
Distinguished Guru
Message 2 of 6
Re: BT Voyager 1010 USB Adapter Driver
Wow, that is going back a few years. I may well still have a boxed one somewhere. Will see what's in the box
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
JK07749423528
Message 3 of 6
Cheers pal
CarolO
Message 4 of 6
Hi,
Did you get the BT Voyager 1010 driver.  I've just found mine, I want to get it working so I can get an old Dell laptop working.  Thanks
Devon_Dave
Distinguished Guru
Message 5 of 6
Check out that well known Internet auction site there is one currently up for grabs.
CarolO
Message 6 of 6
Thank you.   In the end I have purchased a usb wireless adapter.  I only needed the driver for the BT 1020 Voyager.  Thank you very much for answering.
