ben_flugel
Newbie
Message 1 of 2
BT Whole Home 5 discs
Good afternoon,
I've been a long time user (almost 2 years) of 3 wifi discs. After just moving into a larger house I yesterday invested in another 2 to bring my total to 5.
These discs have been added successfully and firmware auto updated to the latest release.
I am struggling to find a way to rename the new discs. The BT app on android only shows my original 3 on the main screen and while it shows all 5 on the second screen in the app, the names are blank with no obvious way to change it. I've had no joy when logging in via a browser either.
Can anyone help me with this? Is it even possible?
Ben
1 REPLY 1
BT Devices Expert
BT Devices Expert
Message 2 of 2
Re: BT Whole Home 5 discs
Hi @ben_flugel, someone had a similar problem a couple of weeks ago which got resolved; have a look here.
Your symptoms are very subtely different, but the solution I think will be the same. (essentially, make sure you use the 'Add Another Disc' button, and do the reset).
Hope this helps. Let us know how you're getting on.
