Message 1 of 4
BT Whole Home Discs (White & Black)
Hi,
Can i please ask if there is any difference between the white BT discs and the Black BT discs that are offered part of the Halo 3?
I already have the white once, and not sure if the neewer ones are different?
Tags (1)
3 REPLIES 3
Message 2 of 4
Re: BT Whole Home Discs (White & Black)
The black discs are for Complete Wi-Fi (as opposed to Whole Home Wi-fi) and the two are not compatible.
Please help the community to help you by including all relevant information, single word responses may be quick to type but they offer little value to this Community Forum and do not help its team of volunteer members to help you.
Message 3 of 4
Thanks Les,
Any idea if they both work the same?
As Bt are wanting £12 extra a month for complete wifi - and if they work the same i see no poit in the upgrade - as not really intrested in the other offerings that come with the Halo offering.
Message 4 of 4
No, they don't work the same way but if you've got a good working Whole Home system then you don't need Complete Wi-FI
