pcj2000
Message 1 of 5
BT Whole Home - Problems connecting when moving between hubs
I have recently installed a dual Hub Whole Home set up but am having trouble with my android phone.
Both hubs are connected and have a blue light. When I initally connect my phone it all works well and I get a good speed. When I move from the primary hub  (the one connected to the router) to the secondary hub it usually works well. However, when I move back into the area of the primary hub I lose my wifi connection.
In my wifi settings it says there is an authentiation error but it works if I switch off wifi then switch it back on.
I have tried forgettign the network and re-enterign the password but the problem still arises.
My phone is a Samsung S6.
Is this a common problem? Anyone know if there is anything I can do?
4 REPLIES 4
BT Devices Expert
BT Devices Expert
Message 2 of 5
Re: BT Whole Home - Problems connecting when moving between hubs
Hi @pcj2000
We're investigating problems with the S6 - see this thread: https://community.bt.com/t5/Connected-Devices-Other/Very-close-to-returning-my-2nd-BT-Whole-Home-WiF...
It'd be useful if you could post your S6 software versions (build number in "About Device > Software Info") on this thread to help.
Do you find this happens every time you move between the main disc > secondary disc then back to main disc? And what sort of time period do you spend with each disc.
Thanks.
Community ModeratorDanO
Show your appreciation!
Kudos”
I am a BT Employee and an expert on BT Devices queries. I am here volunteering my own time to give advice, and help where I can with BT device queries. Go here for more info.
pcj2000
Message 3 of 5
Thanks Dan
My Android 7.0 version G920FXXU5EQKF
It doesn't happen every time, but I can't go back and forth between them. If I stay in the same area it will stay connected fine (e.g overnight was fine last night), the problem only arises when I move.
Cheers
Peter
Message 4 of 5
I'm also having the save problem with my S6
Software V7
G920FXXU5EQKF
Rob
MintyTrebor
Message 5 of 5
FYI: Just posted here
regarding this issue. Did not want to dual post.
