Message 1 of 3
BT Whole Home Remove Ethernet From First Device After Setup?
OK - all setup fine
1st device connected via ethernet to Virgin router
2nd device wi-fi to first
3rd device wi-fi to 2nd
Now it's all setup can the ethernet to the router be removed and the first device connected via wifi to router?
2 REPLIES 2
Recognised Expert
Message 2 of 3
Re: BT Whole Home Remove Ethernet From First Device After Setup?
No the Whole Home system requires one dis to be connected via the Ethernet port to work.
Message 3 of 3
sadly, Ta
