PAno
Message 11 of 18
Re: BT Whole Home W10 Cant Connect to Network
Issue seems to be when using 5.2GHz. Using b/g restricts you to 2.4GHz which has more issues with interference. (Not sure if it still uses n).
Oxlade1
Message 12 of 18
Look out for a new firmware upgrade next week that includes a fix for this issue.
PAno
Message 13 of 18
Sounds. Looking forward to it. Thanks for the heads up.
BT Devices Expert
BT Devices Expert
Message 14 of 18
The new firmware has gone live today. Could you reply to confirm you can connect without the workaround now?
Thanks.
Device expertDanO
Show your appreciation!
Kudos”Kudos”
est1865
Message 15 of 18
Hi laptop conected without issue after firmware update looks certainly for a Dell using Intel Centrino Advanced N - N6205 chip issue has been resolved
Thanks for following this issue through
PAno
Message 16 of 18
Looks pretty good for me. Used to kill me Wifi NIC straight away but been online for a while with no issue. Thank you 🙂
dazla
Message 17 of 18
I can confirm that the Lenovo X230 with the Intel Centrino Advanced N - N6205 now works perfectly. Thanks for the fix 👍
Wjs001
Message 18 of 18
Whole Home WiFi has just had an App/Firmware update so it may be worth giving a test now from your original settings (obviously manually check wether your WHW has updated first) 👍
