hj1987
Message 1 of 5
BT Whole Home WIFI - 3rd disc won't connect to 2nd disc, only to first
Is there anyway to ensure that the third of our 3 BT Whole Home WIFI discs connects to the second disc, rather than getting the weak signal from the master disc?
At the moment we have:
Disc 1:
--Disc 2 -- Disc 3
I would like:
Disc 1:
--Disc 2:
----Disc3
Hope that makes sense?! Thanks in advance for any help.
Tags (1)
4 REPLIES 4
ioannis
Message 2 of 5
Re: BT Whole Home WIFI - 3rd disc won't connect to 2nd disc, only to first
There’s no way to do this manually. You’ll have to power on the third disk after the second has initialised and connected to the master disk. Hopefully then it will recognise the second disk as the closest one. I’ve had the same issue with one of mine and that was the only way I could get it to connect to the closest disk. I’ve found that if the signal difference is not dramatic it will aim to connect to the master disk for what I assume is to reduce latency through multiple hops
Moderator
Moderator
Message 3 of 5
Hi @hj1987 and welcome.
Sorry for the delay in getting back. Have you tried the advice posted by @ioannis. Can you post back and let us know how you're getting on?
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Oxlade1
Message 4 of 5
And to add, if you are certain you want it to connect via the second disc (which will add latency and reduce overall performance) to get a stronger signal, you could try moving the third disc slightly further away from the first disc to influence the disc decision making to pick which to connect to.
jaybeetoo
Message 5 of 5
My 3rd disk sorted itself out after being left for a few days.
