Hello:
I have an issue with my 3x Whole Home Wi-Fi units ( white ), controlled by the Whole Home Wi-Fi App.
I had a major power-cut at home, one of the things I lost control of is the management of my 3x units. I can no longer "see" them via the app. At the moment the app shows the installation of 3x units and at a certain point just stops.
I seem to be going around in circles in trying to sort this out. I would be grateful for assistance or suggestions. I have seen and read, a post guideline for Whole Home Wi-Fi on the forum. I tried these suggestions without success.
The power-cut seemed to affect my router, which I have corrected. The control I have over the units is just via my iPhone and the Whole Home Wi-Fi app. Which I have trashed and downloaded again.
Grateful for any help please, as I think I am going a little-mad!
regards
Mike
Solved! Go to Solution.
Hi @mikegunnill and thanks for posting.
I'm sorry you're having problems with your Whole Home Wi-Fi set up. Your best bet would be to contact the BT Whole Home Wi-Fi helps desk . They should be able to get this sorted for you.
Cheers
David
Thank you for your reply David, I am grateful.
I contacted them as you suggested and they have agreed to replace my 3x units as faulty. Thank you for your help, hopefully I will be up and running again soon.
Kind Regards
Mike
