spazicus
Message 1 of 7
BT Whole Home WiFi Firmware localhost bug
Hi,
I have been experiencing many DNS requests to my own DNS server (PiHole) from the BT Whole Home wifi disks.
Below is an an image of the DNS queries from a single BT disk (after being factory reset) with no clients connected:
It is hammering my DNS server with multiple localhost requests.
This behaviour only started with the latest v1.02.03 build03 firmware.
Please can this be resolved.
Thanks!
6 REPLIES 6
Keith_Beddoe
Message 2 of 7
Re: BT Whole Home WiFi Firmware localhost bug
spazicus
Message 3 of 7
The thread concludes with:
"Its probably a software bug."
Let hope BT are made aware of the bug and resolve it...
spazicus
Message 4 of 7
Issue now fixed by firmware v1.02.04 build10
Thanks!
Dan-O
BT Devices Expert
BT Devices Expert
Message 5 of 7
@spazicus
Excellent, thanks for the reply to confirm this!
Dan-O
miltonb120
Message 6 of 7
I haven’t updated to latest firmware because of issues mentioned on this forum! Can you confirm if it’s a few unfortunate ones with issues or is the issue widespread meaning I should hold back on upgrade of firmware
Deryman
Message 7 of 7
Dan-o, I suggest you get on the case fixing the major problems with BT’s rubbish wifi product rather than lurking to say thanks for one persons problem going away. There are a large number of seriously Pi##ed off paying customers with not-fit-for-purpose product out there.
