Puntoboy
Message 1 of 22
BT Whole Home WiFi - SSID Spaces
Just setup two new discs at my home which was nice and easy. Now I’d like to change the SSID so that I don’t have to rejoin all my devices.
I’ve gone into settings and checked the help files which states that I cannot have Spaces at the beginning of end of the network name. The SSID I use only has spaces in the middle but the app won’t accept it.
Any ideas why this is? As soon as I remove the spaces it works but that doesn’t help me.
21 REPLIES 21
Message 2 of 22
Re: BT Whole Home WiFi - SSID Spaces
spaces are not accepted
Puntoboy
Message 3 of 22
At all? That’s not what the documentation says. Why can my HH6 have spaces but these cannot?
Message 4 of 22
just the way firmware is set up - some router accept spaces whilst others do not
Puntoboy
Message 5 of 22
If that’s the case they need to fix it.
Message 6 of 22
that's not going to happen  obviously changed for hh6
Message 7 of 22
I somehow think BT will take the view that it is easier for you to "fix" your chosen SSid not to include spaces and to re-connect your devices to that SSid than for them to re-write software to "fix" something that is not broken but was designed that way.
Puntoboy
Message 8 of 22
If it was designed that way, why does the documentation say otherwise? It clearly says no spaces are the start or end. Nothing about no spaces at all.
Message 9 of 22
Perhaps the documentation needs fixed.
Puntoboy
Message 10 of 22
BT are clearly capable of fixing the SSID issue, they managed it on the HH6. So why not these?
