Hi
Is there any way to force a wireless device to connect to 2.4Ghz or 5Ghz from the disks ?
I'd like to test an Android device on both but Android have removed the option to select the frequency used.
Solved! Go to Solution.
@MadPantherwrote:Hi
No there is not
Ok. Thanks
