MadPanther
Message 1 of 3
BT Whole Home Wifi Choose Frequency..
Hi
Is there any way to force a wireless device to connect to 2.4Ghz or 5Ghz from the disks ?
I'd like to test an Android device on both but Android have removed the option to select the frequency used.
2 REPLIES 2
Steve59
Message 2 of 3
Re: BT Whole Home Wifi Choose Frequency..
@MadPantherwrote:
Hi
No there is not
MadPanther
Message 3 of 3
Ok. Thanks
