Tranquility
Message 1 of 22
BT Whole Home Wifi Secondary Disc Ethernet Node Connection?
Hi There,
I wish to connect PCs via an ethernet hub to the ethernet port on a secondary (remote) BT Whole Home WiFi disc, rather than use it as a hardwired Backend Ethernet connection, as is it's primary purpose, is this possible? E.g. ....
PCs <--Ethernet--> Hub <--Ethernet--> Secondary Disc <== WiFi  ==> Primary Disk <--Ethernet--> Internet Router
I don't want to buy the system if I can't do this.
Thnaks!
21 REPLIES 21
Message 2 of 22
Re: BT Whole Home Wifi Secondary Disc Ethernet Node Connection?
Tranquility
Message 3 of 22
Thanks Keith, but that link is innaccessible to me, the server does not reply? Maybe because I do not have BT broadband? I did try it earlier & it comes from another question posted here that is not the same as my question, or as straight forward. Thus I was unable to accurately ascertain an answer. I don't want to spend money on equipment that does not fulfil my requirements!
Message 4 of 22
It was only an image, see below
Tranquility
Message 5 of 22
Having some problems with this setup, as soon as I hard wire a pc or switch to the slave whole home wifi device via Ethernet, the device disconnects from the master. It looks like the backhaul gets rerouted through the Ethernet port and thus fails. I can't see any way to stop the backhaul from rerouting.
This is a show stopper for me so any help would be apreciated!
Message 6 of 22
May be worth asking @Dan-O the BT Device expert, as I cannot see why this should be an issue, and I am sure others have got it working, as the picture I posted was related to an earlier thread on this forum.
An Ethernet switch should simply pass the data  to the PC, unless there is something within the software which prevents this. It does need to be verified.
Tranquility
Message 7 of 22
Hi Keith,
I should add that I by-passed the switch and plugged the PC straight into the Whole Home device. My phone connected to it & I could ping the PC, it's just that the WiFi mesh was offline.
Chris
Message 8 of 22
I think we will have to wait for a reply from the BT Devices expert.
Message 9 of 22
@BrunoN
Can you help @Tranquility on this thread please?
BT Devices Expert
BT Devices Expert
Message 10 of 22
@Tranquilitywrote:
Hi Keith,
Chris
Hi @Tranquility, if I read this thread correctly, in summary you're simply now trying to plug a PC to the Ethernet port on the back of a secondary disk and that doesn't work? The short answer is that scenario should simply just work... So obviously something else is going on.
Could you describe your symptoms in a bit more detail (in particular, what do you exactly mean by your WiFi mesh was "offline"?), and maybe someone else can help if they've seen this before.
Otherwise, please contact the helpdesk as these symptoms may be hiding another underlying issue which they'll need to resolve first.
Community ModeratorBrunoN
Show your appreciation!
Kudos”
I am a BT Employee and an expert on BT Devices queries. I am here volunteering my own time to give advice, and help where I can with BT device queries. Go here for more info.
