Message 1 of 4
BT Whole Home Wifi
I am thinking of purchasing this for my daughter but she wants to completely disable wifi at night.
Can you completely disable BT Whole Home Wifi?
If not in the settings I assume you can just disconnect the ethernet cable at night but this is a bit clumsy!
3 REPLIES 3
BT Devices Expert
BT Devices Expert
Message 2 of 4
Re: BT Whole Home Wifi
Hi blackswan,
There are no options within the App and/or Web interface to completely disable the Wi-Fi - as that would ultimately render the discs non-functional.
The only way to disable Wi-Fi at night would be to turn ALL the discs off.  Disconnecting the Ethernet would not disable the Wi-Fi on the discs, as they would still maintain a local network connection between each of the discs.
Hope that helps
Darren_B
Message 3 of 4
Thanks Darren,  suspected as much.
When the  discs are turned back on in the morning I assume there will be no configuration issues and the wifi will just start straight up??
BT Devices Expert
BT Devices Expert
Message 4 of 4
Hi,
Yes the discs will startup with out any manual intervention from yourselves.  It could take 3~5mins for all the discs to stabilise on a chosen network topology.
Darren_B
