Message 1 of 3
BT Whole Home Wifi
Hi,
Quick question about BT Whole Home Wifi - would 2 x Twin Packs work together as one mesh?
2 REPLIES 2
Message 2 of 3
Re: BT Whole Home Wifi
Hi @Marcod yes that's correct, you just need to make sure they're the same version of Whole home wifi discs.
Cheers
Neil
Message 3 of 3
Great, thanks for the quick reply
