Labrajaws
Message 1 of 9
BT Whole Home - increasing number of ethernet ports on discs
I would like to increase the number of ethernet ports I can plug devices into on the Whole Home discs (the ones not connected to the router i.e. the 'satellite' discs).
Is this possible by plugging an Ethernet switch into the back of the discs and then connecting multiple devices into the switch's ethernet ports (Smart TV, XBox, Freeview box etc).
If so, does this give a faster/more reliable connection to the discs (than a Wifi connection) for things like Netflix on a Smart TV or gaming on an XBox?
Andy
8 REPLIES 8
Keith_Beddoe
Message 2 of 9
Re: BT Whole Home - increasing number of ethernet ports on discs
@Labrajaws
Yes you can do that. Whether its any faster is going to depend on the wireless speed between the disc and the master disk. Here is an example.
Labrajaws
Message 3 of 9
Thanks @Keith_Beddoe
Wouldn't the improvement depend on the wireless speed between the device (e.g. XBox) and the disc it is connecting to?
Wired via cat5e/cat6 cable:  1000MBps (if no other devices using switch)
Wireless: 2600MBps (maximum)
Regards
Andy
Keith_Beddoe
Message 4 of 9
I assumed you wanted to connect hard wired devices to the Ethernet switch?
I do not know whether the performance would be better that a direct wireless connection, as that would depend on the environment. I am not familiar with that product, as it not specific to BT, as its just a retail product.
Labrajaws
Message 5 of 9
All my devices where speed/performance is important (Smart TVs and XBox) have both ethernet ports and wifi capability. Hence I'm just after the best connection to each disc - wired vs wireless.
Andy
licquorice
Message 6 of 9
Speed can only be as fast as the slowest link in the chain. I.e for internet connection your DSL speed will be the governing factor. The only time wifi speed is relevant is when connecting between devices on your LAN, e.g smart TV to NAS.
gg30340
Message 7 of 9
If you connect your Smart TV and XBox by Ethernet to the Ethernet switch which is connected to the disc, you are still ultimately connecting by wireless. ie wireless from the Smarthub to the disc so you would be as well doing away with the Ethernet switch and use the wireless connection on your devices.
You would only have a "proper" Ethernet connection, which is the best way to connect Smart TV and XBox for the best speed, if you connect by Ethernet directly to the Smarthub.
northshields
Message 8 of 9
Or possibly a Homeplug arrangement would work better than connecting to the disc?
linka6979
Message 9 of 9
Is it possible to link the discs back to the hub using cat 5 cables for better performance? Thanks in advance
