ChrispyB
Message 1 of 2
BT Whole Home set up help
Hi
I have just bought a 3 disc Whole Home kit.
I have set up the first disc and it’s linked to the router. The WH network has been renamed to the SSID of the original Home Hub 5 router, the HH5 has been renamed and Wi-fi disabled. The Whole Home disc is working fine.
The other 2 discs are set up using Wi-Fi. Each is showing a solid blue light but I can’t see them in the app, the only disc showing is the first. And I don’t think they are transmitting a signal, despite the solid blue light.
Any thoughts would be appreciated.
1 REPLY 1
Paul_31
Message 2 of 2
Re: BT Whole Home set up help
When adding discs 2 & 3, did you first connect them to the router to allow them to sync the correct Wi-fi details? If you didn’t that might help.
Also I have read on here that some users have had to re-install the app on their device to get it to work and recognise the disks.
Do all three discs show up if you access them via the web interface: mybtdevice.home
