brummygit
Message 1 of 26
BT Whole Home v1.02.03 build03 guest network
I've just updated my BT Whole Home WiFi to v1.02.03 build03.
I see this update adds guest network functionality - can I use this to share out my BT WiFi from my Smart Hub?
25 REPLIES 25
BT Devices Expert
BT Devices Expert
Message 2 of 26
Re: BT Whole Home v1.02.03 build03 guest network
Hi @brummygit
The new Guest Network functionality on Whole Home Wi-Fi creates a separate network, with a different network name/SSID and password from your main Whole Home network to allow you to provide guest access.
Devices connected to this network only have Internet access and no access to devices on your local network. They also have a reduced amount of bandwidth compared to your main network.
This is separate from BTWiFi - Whole Home Wi-Fi is designed to work with all broadband providers.
Device expertDanO
Show your appreciation!
Kudos”Kudos”
Danfard
Message 3 of 26
I have BT Whole Home WiFi and just updated my 5 discs - the app said "updating...", turned them all red in the app, then reported an essential update was required for the app from the Play Store. There is no update available however. Cannot use the app as I just get the aforementioned message on startup.
Any ideas?
BT Devices Expert
BT Devices Expert
Message 4 of 26
Hi @Danfard,
Please bear with us - an update for the Android app will be available shortly. I'll update on this post when it's available.
Thanks.
Device expertDanO
Kudos”Kudos”
Danfard
Message 5 of 26
Cheers Dan-O.
BT Devices Expert
BT Devices Expert
Message 6 of 26
In the meantime you can access some of the new features using the web interface.
From a device connected to your Whole Home Wi-Fi network (via Wi-Fi), go to http://mybtdevice.home and log in with your admin password.
Device expertDanO
Kudos”Kudos”
trapdoor
Expert
Message 7 of 26
Is there any way to set the bandwidth limit on the guest network or is this fixed? If as I suspect it is fixed, can anyone say what the reduced bandwidth is?
peterh0001
Message 8 of 26
My App has now started working again so they must have updated something.
Peter
BT Devices Expert
BT Devices Expert
Message 9 of 26
Hi @trapdoor
Not at the moment - look out for more improvements in the future around extra control.
The Guest Wi-Fi bandwidth set at 20% in the latest firmware.
Thanks.
Device expertDanO
Kudos”Kudos”
brummygit
Message 10 of 26
I ran a speed test via the guest network and was able to use the full bandwidth of my connection. Does the bandwidth throttling only apply when contending with normal clients?
If that's the case how will it get on sharing with wired clients on my LAN?
