marcobongo
Message 1 of 4
BT Whole Home
I have an issue setting up Alexa enabled devices. they are only able to pick up the 2.4GHz channel. on setup mode when you connect directly to these devices with their applications that you have on your phone , the phone itself needs to be on  2.4GHz  if not you cannot connect to the device. invariably my phone is on 5GHz. there appears to be way to switch my phone manually over to the 2.4GHz channel, which is extremely frustrating. does anyone know a fix
3 REPLIES 3
imjolly
Message 2 of 4
Re: BT Whole Home
Which hub version do you have?
marcobongo
Message 3 of 4
Re: BT Whole Home
It says hardware version 01
software v 1.02.08 build 02
Darren_B
BT Devices Expert
BT Devices Expert
Message 4 of 4
Re: BT Whole Home
Hi marcobongo,
We have added a new feature in the Whole Home web GUI to support the on-boarding of 2.4GHz IoT/Smart devices.
This new firmware is available to install by enrolling on to the Early Adopter programme.
If you wish to enrol to this, then visit the Whole Home Wi-Fi web GUI via http://btwhole.home (whilst connected to the WHW network).
Under System -> Firmware Update, select Enable under the 'Early Adopter' section.
Save the changes, then do a Firmware check, which will offer you the new firmware. Complete the upgrade.
Once upgraded, return to the web GUI and navigate to Setup -> Wi-Fi, then select Enable under the '2.4GHz Device Setup Mode'
Any problems, just reply here.
Darren_B
