dpb
Message 1 of 42
BT Whole home: connection but no internet
After several months of good service the latest firmware update V1.02.06 build 11 which was installed 0n 11/10/18 seems to have messed things up. Although I get an excellent Wi-Fi signal on devices, internet connection is lost. I've tried things like switching everything off. If I switch to another wi-fi signal and then go back to Whole Home I get internet for a short period before it goes again. Any suggestions?
41 REPLIES 41
BrunoN
BT Devices Expert
BT Devices Expert
Message 2 of 42
Re: BT Whole home: connection but no internet
Hi, do you get that problem with all the devices around your home or just some of them? If the latter, what are they?
dpb
Message 3 of 42
Hi
Seems to be affecting everything:
IPAD2
IPAD Air 2
Moto G5S plus - phone
Samsung TV UE49MU7000
Would appreciate any help including ability to roll back.
dpb
Message 4 of 42
Problem seems to have been resolved (fingers crossed) by turning off the discs and then the router before restarting the system.
JSHRIB
Message 5 of 42
I have had the same problem. No internet despite all discs blue on iOS and macOS devices.
Switching off hub and router fixes it for a few days. Only been happening in last few weeks.  ? since last automatic firmware upgrade to bt whole home app. Current firmware is v1.02.06build11  updated on 10/10/18.
chrisneelyuk
Message 6 of 42
I too am having the exact same issue since updating to 1.02.06 build 11. They all show as connected and blue but there is no internet connection. Only solution is to reboot discs and master however the next day the problem is back. I have 4 discs. VERY ANNOYING.
dpb
Message 7 of 42
Did you also switch off your router? Not sure if you mean router when you say master. 24 hours after switching off the router and the discs, my system still seems to be ok. Fingers crossed.
chrisneelyuk
Message 8 of 42
I've tried rebooting the router then the master and all the other discs and this temporarily fixes it but after an hour or the connection drops and the app says no internet connection. I have disabled all Steering setting and this has made no different. All my devices are Apple: Macbook pros, Airs, iPads and iPhones.
This is seriously painful and is now affecting my work. Come on BT please off a fix for this. I have enabled the 'Early Adopter' setting, please provide all of us with a fix as this is not acceptable. I bought 3 discs and a further 2. Before I start leaving reviews on Amazon, Facebook and twitter etc please offer a fix for this!
chrisneelyuk
Message 9 of 42
This has not be resolved and the solution does not work!
Inmaterichard
Message 10 of 42
I have the same issue, this has NOT been solved. Rebooting is only a temporary fix. Another duff firmware update!
