Message 11 of 42
Re: BT Whole home: connection but no internet
Also having the same issue on multiple devices since updating to latest firmware 3 days ago, no issues with previous 2 firmware versions. Full WiFi signal icon displayed on device with exclamation point showing connected but no internet, have to spend 5 mins disconnecting reconnecting etc then it happens again at least once a day.
multiple devices eg moto G5 on Android 7, Nokia 5 on android 8.1, iPad on iOS 12.0.1 etc. Unhappy family.
I have 3 disc setup on firmware v1.02.06 build 11. I have auto update turned off. Mods,  Please don’t mark this as resolved until permanent bug fix issued rather than temp workaround.
Message 12 of 42
Every 12 hours both router and master home hub now need switching on and off to maintain internet connection despite all hubs blue and apple devices showing adequate WiFi bars. All since latest firmware update. Are BT listening???
Message 13 of 42
Can't really believe it's a factor but I have my router wi-fi on which I hadn't before. I've been ok for 3 days now.
Moderator
Moderator
Message 14 of 42
Hi @JSHRIB sorry you are experiencing a fault with your Whole Home Wifi.
Please contact the helpdesk on: 0808 100 6116  Mon - Friy 9.00am to 5.30pm, Sat 9.00am to 2.00pm or drop them an email to: btconnectedhome@bt.com
They will be best placed to help you resolve this problem.
Cheers
John
Aspiring Member
Message 15 of 42
Also getting these same symptoms. A reboot provides a temporary but eventually devices connected to the child discs cannot access the internet. The main disc directly attached to the router seems to retain access.
Message 16 of 42
I had this reply from BT guy:
“Hi @JSHRIB sorry you are experiencing a fault with your Whole Home Wifi.
Cheers
John “
Did extensive diagnostic for BT following this and the result was they replaced all 5 BT whole home discs FOC! The BT engineer on the phone made very clear not to update the firmware which has clearly caused the problem in the first place. My new discs have an earlier firmware. Hope this helps. Ring the number.
Message 17 of 42
Identical problem. Neither booting mesh system not router fixes it for long. I’m unable to work over Wi-fi reliably now so am scrapping the whole mesh system
Message 18 of 42
@JoBlo I also have the same problem however with all the steering disabled it continues to work. Have you tried turning all the steering off as suggested earlier in the post.
Message 19 of 42
Thanks for trying to help but yes, already tried that. Tbh I’m sick of the whole system now so will bin it and switch to power line
Message 20 of 42
I never actually totally lose my internet connection but system is certainly less stable than it was before. I am pretty certain it is down to dual band capability.
The first thing I noticed was the app on my iPhone kept flicking between OK and offline/no internet connection. Although internet was working fine. I fired up an old 2.5 GHZ WiFi only phone, installed the app and it is fine.
then a printer that had been rock steady for 3 years starting dropping off line after about 10 mins of restarting either the WiFi or the printer. Fixed by turning WiFi back on on my Sky hub and splitting config of 2.5 and 5 GHz bands, and connecting printer to just one of them.
Now I have noticed that if I try to watch my Nest cam for an extended period from my tablet it keeps reporting lost connection to Nest. The camera connection is fine, it is the iPad to a Nest that drops.
