edcreasey
Message 1 of 2
BT WholeHome Can’t Connect a 2.5Ghz device
I have a smart plug that can’t connect to my Whole Home hub in my office.  I think it’s because it’s a 5Ghz hub and a 2.5Ghz smart plug.  I’ve checked in mybtdevice.home but it doesn’t appear to have a feature where I can change the hub to 2.5Ghz.
1 REPLY 1
tsr2
Message 2 of 2
Re: BT WholeHome Can’t Connect a 2.5Ghz device
The WholeHome supports 2.4GHz and 5GHz connection, so the 2.4GHz band isn't the issue.
