Newbie
Message 1 of 3
BT WholeHome WiFi Ethernet
Hello all,
this may be a simple question, but it is baffling me!
Do I have to have a router before connecting my BT Whole Home Wifi or can I buy an adapter to plug it straight into the wall? Currently, it runs into my old BT hub with wireless disabled before being connected via ethernet to the WholeHome Wifi.
2 REPLIES 2
Message 2 of 3
Re: BT WholeHome WiFi Ethernet
Welcome to this user forum.
You need to have a router. If you attempt to plug it into a phone socket, you will  damage it, as there is 50 Volts on a phone socket.
Newbie
Message 3 of 3
Many thanks for your quick reply!
