Message 1 of 20
BT WholeHome and Google Home devices
Hi,
I have two Google Home devices - a full size "home" and "home mini".  All was fine with both on my BT WholeHome system until I upgraded to firmware v1.02.03 build03 on the BT WholeHome system.  Now both of the Google homes experience frequent drop outs on the network - Google home says it "can't connect".  I've moved both the Google homes around the house, but even when placed next to BT WholeHome disc, I get the same issue.
Connecting the Google Homes direct to my router wifi (i.e. not the BT WholeHome mesh network) solves the issue.  Any one else experiencing similar problems?
Anyone know how I can go back to the previous BT WholeHome firmware?
Thanks,
19 REPLIES 19
Message 2 of 20
Re: BT WholeHome and Google Home devices
Try asking on this thread, as some people were having issues after the upgrade.
Introducing BT Whole Home Wi-Fi
Message 3 of 20
Hi
im having exactly the same problem
since the last firmware upgrade my google home devices keep losing Wi-fi connection
after about 10mins of streaming audio it stops . Trying to replay generally says there’s a glitch or unable to connect to WiFi.  About about a minute I can usually Rea start streaming
all this is definitely linked to the firmware update  as everything was working perfectly beforehand.
Have cold started the d full Wi-fi network numerous times but the problem still occurs
thanks in advance
gary
Message 4 of 20
I have this issue and have put it down to the fact that the Google Home occasionally switches between different discs.
Is it possible that this is happening to you?
Message 5 of 20
Possible, but doesn't really explain why all was fine with the previous version of firmware, unless BT have made the switching more agressive.
Spent some time with a Google support engineer trying to resolve the problem, and we couldn't.  Eventually we came to the conclusion that there must be some kind of campatibility issue that has been introduced in the latest version of the BT WholeHome firmware.  Hopefully BT will read this and investigate further!
Message 6 of 20
Fingers crossed.
Message 7 of 20
Me too on this. 5 Google Home devices. Also seems an issue with Samsung S6 Edge phones. Have 2 of them with frequent drop outs. I receive authentication errors on them. Everything else of mine fine. Though I've only just set it up having bought for Christmas.
Message 8 of 20
If that's the case is there a way of rolling back the device firmware and stopping it from updating?
Member
Message 9 of 20
I'm having the same problem following the firmware update with both my google home and google home mini devices
streaming keeps stopping after 5-10 minutes... devices are regularly reporting a glitch when I try using voice control, and I keep spotting the google home devices enabling the temporary networks that they create when waiting to be setup
I also get the impression that some of my other devices are also getting less reliable wifi connections than before.
Im not using any of the new network features so would downgrade if I could
If this isn't fixed soon I'll be reenabling my previous wifi network and moving devices back on to that
Message 10 of 20
Yep my google homes are messing up every now and then.
Any input from BT?
