AxeMcAxe
Message 1 of 4
BT WholeHome ethernet has wrong name
3 disc system installed.  All 3 discs correctly broadcast their BTwholehomeVTN wifi id, but if I connect anything to the ethernet of  the 3rd disc it identifies as a netgear range extender's id.  (That was in place when I first installed the discs, but is now turned off. )
Have factory reset the whole system, including the router, but it still identifies as the range extender's id.
Seems very weird
3 REPLIES 3
Moderator
Moderator
Message 2 of 4
Re: BT WholeHome ethernet has wrong name
@AxeMcAxe our BT Whole Home Wifi expert @Dan-O may be able to help when he's next on the community.
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
BT Devices Expert
BT Devices Expert
Message 3 of 4
Hi @AxeMcAxe
Do you mean that the device shows under Whole Home Wi-Fi devices list as a Netgear Extender or do you mean the name that is shown for the Ethernet connection in Windows 10 for example?
Dan-O
Device expertDanO
Kudos”Kudos”
AxeMcAxe
Message 4 of 4
Hi
On the 3rd disc only, the Ethernet connection has the Netgear Extender's name.  as far as I can tell it broadcasts the correct BT Wifi name.
