mansourdom
Message 1 of 8
BT Wholehome not working with gigacube
I just bought a new gigacube mobile router with 4g from vodafone.
It's set up and working fine. I also have a new BT wholehome kit to run the signal through the house. It says to connect the wholehome direct to the router ethernet port. when i do this into gigacube box, the line drops every time from the gigacube box and i have no signal, nor does the disc receive anything. Disc lights flash purple/ blue and then stay red.
Unplugging it and the signal immediately comes back. Any ideas on how to get this to work?
7 REPLIES 7
imjolly
Message 2 of 8
Re: BT Wholehome not working with gigacube
don't think it is intended to work with mobile 4g
mansourdom
Message 3 of 8
thanks, if that's right is there no way to use some other device to get the signal across the house? I've terrible 4g, so the only place is in a far corner of the house.
Keith_Beddoe
Message 4 of 8
BT hotspot 600, simple and cheap. It uses the mains wiring.
mansourdom
Message 5 of 8
do you think that will work with the gigacube?
Keith_Beddoe
Message 6 of 8
I cannot see any reason why not, as all it does is to extend an Ethernet connection. It does request an  IP address using DHCP, but you can configure it to a static IP address.
mansourdom
Message 7 of 8
thanks, this works fine - and also i can use the wholehome too through the hotspots
Keith_Beddoe
Message 8 of 8
Excellent !
