Message 1 of 2
BT Wi-Fi Discs (Black) as wired Access Points, is it possible?
Is it possible to use the WiFi discs as a wired access point (i.e. using the ethernet port cabled into the router) if my router is not the homehub router?
I'm using a Draytek 2860 if that makes any difference.
Thanks.
1 REPLY 1
Message 2 of 2
Re: BT Wi-Fi Discs (Black) as wired Access Points, is it possible?
Thanks.
No, the discs need to be paired to the BT Smart Hub 2, they will not work with any other router.
