Message 1 of 6
BT Wi-Fi Discs
Hi,  Before I purchase another, Is it possible to have more than 3 BT Wi-Fi Discs  as I have a CCTV camera that will not connect Wirelessly only works when connected directly using Ethernet?
5 REPLIES 5
Message 2 of 6
Re: BT Wi-Fi Discs
Hi, @sparker1 what discs do you have? If they're whole home wifi discs (white) then yes you can add another disc to the three you already have, it has to be the same model though.
Neil
Message 3 of 6
Re: BT Wi-Fi Discs
Hi Niel,   Thanks for that  they are the BT ones used by EE,  the white ones.  I will check the modle and try it
Message 4 of 6
Re: BT Wi-Fi Discs
Hi @sparker1, thanks for confirming that info. You can check out the Whole Home Wifi family of products and as Neil has said you can only add a disc from the same product.
cheers
John
Message 5 of 6
Re: BT Wi-Fi Discs
Thank you John,   The disc supplied by "EE"  is WE410443-OT so to confirm  I can add another of these to my existing 3?
Regards,
Dave
Message 6 of 6
Re: BT Wi-Fi Discs
Hi @sparker1, do your discs have the BT logo on the middle of the disc?
If not then I think you may have the EE Smart Wifi discs and you would need to check with EE if it is that product.
cheers
John
