HarryUK
Message 1 of 2
BT WiFi Disc Versions
Hi
I have FTTP and a smart hub 2. I want mesh system for a 5 bed house. Happy to purchase outright or via BT. I have seen black and white versions of the discs.
What are the differences and which option would you recommend?
1 REPLY 1
DavidM
Moderator
Moderator
Message 2 of 2
Re: BT WiFi Disc Versions
Hi @HarryUK and thanks for posting about the wifi discs.
You'll find details on the wifi discs at complete wifi . My own preference are the black set simply for the aesthetics to be fair.
Cheers
David
