Message 1 of 2
BT Wifi Discs - Stands
Afternoon All,
I have three of the black wifi discs scattered around the house. They have always worked great - except for the two flippy feet that are on the bottom. All three of the discs are missing at least one.
Has anyone come up with a way of making them stand up? A 3d printed stand maybe?
Would love to hear from you.
Gareth
1 REPLY 1
Message 2 of 2
Re: BT Wifi Discs - Stands
Hello kyconnect gov@garethedmondson,
It seems you’re not alone in facing the issue with the flippy feet on the BT Wifi Discs. While there isn’t a specific stand available for purchase, there are a couple of solutions you might consider.
If you have access to a 3D printer or know someone who does, creating a custom stand could be a great solution. There are online communities and platforms where you can find 3D printing enthusiasts who might have already designed such stands, or you could design one yourself if you have the skills.
You could use common household items to create a makeshift stand. For example, using non-slip pads or mounting putty can help keep the discs upright. Alternatively, you could repurpose any small stand or holder that fits the size of the discs.
Some users have suggested contacting BT or a third-party provider for replacement parts or stands1. It’s worth reaching out to see if they can offer a solution.
Best Regards,
kyconnect gov
