FeltonMK
Message 1 of 2
BT Wifi Extender
Hi
A non-techy post.
Can you de-select devices that are connected to a BT Wifi Extender? So they connect to the main Wifi instead.
My laptop and phone which are really close to my router are connected to my Wifi Extender which is on the 3rd floor of my house and signal is weak.
Ive hunted for a solution with no luck.
Many Thanks
1 REPLY 1
Anonymous
Not applicable
Message 2 of 2
Re: BT Wifi Extender
It depends how you set them up, if you just used them straight from the box then yes.
The wi-fi extender will have it's own network ID which will be different to your router ID, simply do a search for the network you wish to connect to (in this case the Hub), click connect and enter the hub password
