Message 1 of 7
BT black WiFi discs
So we're moving house, and at the new address fibre 1 is the fastest speed we can get so we're downgrading to this. The problem is you can't get complete WiFi on the package.
I know it's a £30 charge if I don't return the disc, but if I do this can I keep using it? We're going to nee some form of extender
Thank you
6 REPLIES 6
Message 2 of 7
Re: BT black WiFi discs
You can get Complete Wifi with Fibre 1. It is a £12 a month add on.
Message 3 of 7
Still worth paying the £30 for the 24 month contract if it will still work though
Message 4 of 7
That's your choice, I was only pointing out that you were wrong when you said you couldn't get it with Fibre 1.
Message 5 of 7
Fair play. The person I spoke to on the phone didn't seem to think so, but I think I also confused them with talking about mesh networks.
Do you know if the disc will still work if I pay the £30 or do BT disable it?
Trying to figure out my options. Moving tomorrow and will test to see if the 1 disc I have is enough, if it's not it's either complete wifi or by a separate mesh wifi system.
Message 6 of 7
The discs are not enabled or disabled by BT.
Message 7 of 7
Great, thank you. Let's see if 1 disc is enough then 🙂
