Newbie
Message 1 of 10
BT box on wall
Hi
I've just moved into my new home and there is a white box 21 cm X 25 cm screwed to the wall just behind the TV. inside are 2 BT openreach boxes the largest box has
 Tel 1 ,port 1, LOS , PON & power lights at the top. The other smaller box has
Status , fault , charging lights at the bottom
What is it ? Does my WiFi connect to it? At the moment the sky man connected my WiFi to the phone socket in the kitchen. If it's not useful I'm getting rid. Thanks in advance. Dave
9 REPLIES 9
Message 2 of 10
Re: BT box on wall
thats an ONT which is for FTTP - fibre to the home.  by wifi connected to phone socket I assume you mean the sky router.  you should have ordered FTTP not FTTC
the box is property of openreach so you cannot 'just get rid of it'
Newbie
Message 3 of 10
Re: BT box on wall
Wow that's alot of abbreviations there captain way over my head could you say it again in a language I understand.
To cut along story short do I need it ? If not BT can have it back.
Message 4 of 10
Re: BT box on wall
FTTP- fibre to the premises could give you a connection speed with BT of about 900mb whereas using phone socket for router will get you FTTC - fibre to the cabinet -  and then existing copper cable from cab to home with max speed 80mb
the ONT belongs to Openreach not BT
Newbie
Message 5 of 10
Re: BT box on wall
Thanks , you are right the router is from sky
I'll switch if off. Not needed.
Message 6 of 10
Re: BT box on wall
sorry I just cannot understand when you have FTTP available why you are not getting that from SKY.
Newbie
Message 7 of 10
Re: BT box on wall
Me too. A asked the sky engineer all about it and he said it wasn't his field of expertise.basically he didn't know. He just plugged it into the phone socket set up the TV and left.
I've no idea how the internet and WiFi works I just use it.
Even the guy I bought the house off didn't know either.  Can I plug the sky WiFi into the box ? Is the plug compatible to the sockets in the box. It's all very confusing.
My phone and WiFi is from sky not BT.
Any advice would be much appreciated.
Cheers dave
Message 8 of 10
Re: BT box on wall
you can't use the box - ONT- as that is for FTTP which you don't have
you now need to start posting on the SKY community forum as this forum is for customers of BT Retail
Newbie
Message 9 of 10
Re: BT box on wall
Thank you for your help
Stay safe. Dave
Recognised Expert
Message 10 of 10
Re: BT box on wall
Some property’s have both fibre to the premises and copper wire service, presumably the person in that address before you , upgraded to FTTP to benefit from the faster speeds and reliability that FTTP offers, but the older copper wire service still exist.
If Sky are your provider , rather than use the FTTP , they are presumably going to use the older slower copper wires to provide your service ( Sky have only recently started to offer FTTP, when you ordered Sky broadband they probably could only offer slower regular broadband , even if the call it ‘fibre’, it’s only to the cabinet , not all the way into the house )
If you remove the FTTP optical network termination ( ONT) then should you ever want faster more reliable service , obviously you will have made that more difficult and possibly more costly , turn it off if you want, but don’t remove or damage it, if not for your own benefit  but should anyone move in after you, for them
