Message 1 of 5
BT cloud not working
4 REPLIES 4
Message 2 of 5
Re: BT cloud not working
BT Cloud is a nightmare at the moment, a fix is expected by the end of this month
Message 3 of 5
Hi, thanks for swift response.  Do you know the cause? It all appears to stem from an update I applied on my windows laptop
Message 4 of 5
Such generosity to offer your time!! Thank you
Message 5 of 5
As you you say, it started with an update to the windows client but seems to have grown.
You might want to take a look at this thread, it should kill a couple of hours to ease the pain of lockdown 😒
https://community.bt.com/t5/Broadband-Extras-Apps-from-BT/BT-Cloud-Won-t-Start/td-p/2117275
