Newbie
Message 1 of 2
BT disks connect to other disks or just hub?
Hi
Have one of the new home hubs with a wifi disk. Disk was easy enough to set up but still doesn't reach my office. Was thinking about getting a second disk, my question is, will the second disk connect to the first disk or does it have to connect to the hub? If my hub is at 0 meters, first disk is at 10 meters the next disk would have to be at 20meters to reach, it can only achieve this by connecting to the first disk. Is this how the technology works?
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: BT disks connect to other disks or just hub?
Hi @joe2003 welcome to the community and thanks for posting your question, yes you're correct the discs will connect to each other to form a mesh network so adding more discs to the wireless network will help you reach your office.
