MisterRob
Message 1 of 8
BT dual-band Wi-fi extender 600 & BT broadband extender 500
I’ve just bought a used BT dual band Wi-fi extender 600 and it is working fine with my BT router. Unexpectedly it also came with a smaller device which says it is a broadband extender 500. Please can anyone tell me, are these two devices compatible? If so, how do I connect them. If not, is there any use for the 500 on its own?
Thanks in advance.
Rob
7 REPLIES 7
Keith_Beddoe
Message 2 of 8
Re: BT dual-band Wi-fi extender 600 & BT broadband extender 500
@MisterRob
Welcome to this user forum.
I doubt that the wifi extender 600 would be compatible, as  the broadband extender 500, is a powerline type device consisting of two units. If you only have one of those extender 500 units, then its no use.
https://www.bt.com/help/user-guides/broadband-and-wi-fi-devices/wi-fi-and-home-networking/broadband-...
and
MisterRob
Message 3 of 8
That is what I guessed. Thank you.
Keith_Beddoe
Message 4 of 8
The 500 unit was probably sent by mistake.
Anonymous
Not applicable
Message 5 of 8
Yes, I believe you can. The procedure, as detailed on page 4 of the userguide is as follows and appears to apply to all BT AV series of extenders
See https://www.bt.com/content/dam/bt/help/legacy-ug/broadband-and-wi-fi-devices/2633%20Broadband%20Exte...
How to add more Powerline extenders to your
existing network
You can expand your home network by adding more extenders to your existing kit.
1 Plug your additional broadband extender directly into a wall power socket.
Make sure the socket’s switched on.
2 Press the Link button on that extender for 5 to 8 seconds. Wait for the Power light to
go back to steady green.
3 Press the Link button again, this time for 1 second.
4 Within 2 minutes, press the Link button on one of the broadband extenders already
in your home for 1 second to complete the connection to the network.
5 Wait for connection to complete. If everything’s okay, the Power and Data indicators
on the extender will light up.
Anonymous
Not applicable
Message 6 of 8
Just for comparison, this is the procedure for the AV600 (sorry no link for this one as I already have the PDF on my drive). See if you can spot the difference, I couldn't.
How to add more Powerline extenders to your existing network
2 Press the Link button on your additional broadband extender for 5 to 8 seconds.
Wait for the Power light to go back to steady green.
4 Within 2 minutes, press the Link button on one of the broadband extenders already in
5 Wait for connection to complete. If everything’s okay, the Power and Data indicators on
the new extender will light up.
MisterRob
Message 7 of 8
Thanks for your reply. Unfortunately, I don’t think it will work at the 600 works wirelessly a s has no link button on it that I can see, whereas the 500 (from what I understand) works through the house wiring. So, I’m guessing the 500 was sent in error, as suggested above.
Anonymous
Not applicable
Message 8 of 8
The link button on the AV600 is on the top to the left of the network connector
