Message 1 of 5
BT hub plug warm
I've just got a BT hub. Is it normal and safe for the plug to be warm please?
Tags (4)
4 REPLIES 4
Message 2 of 5
Re: BT hub plug warm
Yes, there are electronic components inside.
Message 3 of 5
please rember    theres a heat wave  and that will make all hubs ot thn thay should , please dop not warry    m its normall,  as lon the room   with the hub is not in a rom over 28c thjen it should be fine
Message 4 of 5
yes it is  as long its not in a room   more then 28c , then it sould be fine
Message 5 of 5
There was not a heat wave in December 2021 when this was posted.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
