Gazalucy
Newbie
Message 1 of 3
BT mini hub power light is only half lit ( dim ) ??
My BT mini connector and BT mini hub are up and running ok.
When trying to add another mini hub the power light is only half lit ( Dim )  and hub will not allow Set up procedure.
2 REPLIES 2
Moderator
Moderator
Message 2 of 3
Re: BT mini hub power light is only half lit ( dim ) ??
Hi @Gazalucy,
Can you try the reset procedure on page 9 of the user guide?
BT Mini Hub User Guide
Once that completes, try it again and let me know how you get on.
DanielS
Gazalucy
Newbie
Message 3 of 3
Hi Sorry for the delay. All good now, reset did the trick.
Many Thanks
Gary.
