Message 1 of 1
BT premium whole home slower than BT whole home
I've just splashed out on a 3 pack of the premium whole home discs to replace my existing standard whole home set up. Before I removed the old discs I ran some speed tests for devices linked to each disc. Next I've put the premium discs in exactly the same position as their precursors, set them up, updated firmware etc. and taken speed tests using the same devices in the same locations. They were lower readings across the board. So I waited overnight to see if there was some sort of machine learning thing going on that would improve the situation, but this morning the results were the same. Any ideas as to how I could improve the situation? There must be something wrong in my setup- these devices can't actually be slower if the settings / setup is correct
