amairb
Message 1 of 2
BT roadband Extender 600 Kit
Hi
I recently purchased this BT broadband extender kit as my router is in another room, it worked ok however it always drops connection. Which means I have to restart the computer or take out the plug for the extender kit and then it gets back to normal. Any help with this? It is extremely frustrating
1 REPLY 1
Anonymous
Not applicable
Message 2 of 2
Re: BT roadband Extender 600 Kit
I have the same problem with the same kit, it works fine during the day then for some unfathomable reason it disappears from my network overnight even though the local end is connected to my router by an ethernet cable no more than 12 inches long.
I've tried everything I can think of but nothing seems to work so I just tolerate presing the reset button on the top of the unit every morning.
Let me know if you find a solution
