Pc07
Message 2 of 3
BT tv
Hi, I will soon have a bit tv box delivered , I currently also have a sky now box that I use, will I be able to have both boxes connected
2 REPLIES 2
Pc07
Message 1 of 3
BT Tv video set up
Hi, I will soon have a bt tv box delivered I heard that the areal cable is connected to the tv box , I have a video DVD player which I will want to continue to use , how would I set this up please
iniltous
Guru
Message 3 of 3
Re: BT tv
I don't know what a 'sky now' box is, but if it's Sky TV or Now TV , either will work alongside BTTV, Now TV is 'internet' TV , and Sky TV is primarily satellite TV , albeit with the ability to connect it to the Internet , BTTV needs an aerial connection and (BT) broadband to provide its maximum content , but won't interfere with whatever you currently have, providing your TV has sufficient inputs for everything you want to connect
