BT Devices Expert
BT Devices Expert
Message 21 of 33
Re: BT video baby monitor 6000 additional camera
@Honda4samwrote:
Good evening. Do you know if all of the cameras in your monitor range ( I have a 6000 ) can connect with the monitor? I.e a camera from the 5000 range with pan and tilt to my 6000 monitor.
Many thanks
Sam
Hi @Honda4sam, yes the 5000 camera works with the 6000 monitor screen.
See my ealier post above for pairing instructions. And also my other post further up for the caveats if you're trying to connect a 2000 or 3000 camera to a 5000 or 6000 screen.
BT Device ExpertBruno
Show your appreciation!
Click on the thumbs up next to a reply to say thanks
Kudos”
I am a BT Employee and an expert on BT Devices queries. I am here volunteering my own time to give advice, and help where I can with BT device queries. Go here for more info.
Honda4sam
Newbie
Message 22 of 33
Thank you. I shall give it a go.
Sugarpoppy
Newbie
Message 23 of 33
Hi there
Would the 7500 camera be able to link to a 6000 parent unit with 6000 camera?
BT Devices Expert
BT Devices Expert
Message 24 of 33
@Sugarpoppywrote:
Hi there
No, they're not compatible.
Kudos”
S4m
Newbie
Message 25 of 33
Hi I can’t see the pose re the 2000 camera. Will the 2000 camera link to the 6000 video parent unit?
Many Thanks
BT Devices Expert
BT Devices Expert
Message 26 of 33
Hi @S4m, yes that'll work. With same caveats as earlier in this post about the 3000 linking to the 6000.
Kudos”
S4m
Newbie
Message 27 of 33
Brilliant thank you. Will connect that one up as only need to use the second one occasionally
Pauline2018
Newbie
Message 28 of 33
Where did you get the additional camera from. Everything I search comes up with the screen as well. I just want the extra camera on its own.
Rkazwini
Message 29 of 33
From a company called Discount Communications - details given to me by BT.  Discount communications: 0800 980 8999
McGuire2016
Newbie
Message 30 of 33
Hi All
Very disappointed to read that we are unable to buy an additional camera for this monitor. We have a toddler and a baby on the way, we live in a town house with our bedroom on the top floor and the kids below, so we need a monitor for each of the kids rooms and we will use them ALOT. We were just wondering, since we cannot simply buy an extra camera, if we bought 2 whole sets would we be able to link both cameras to both parent bases? So that we could leave one parent base in our room for the night and one parent base downstairs for the day and have both bases linked to the cameras in each of the kids rooms? Hope that makes sense! A bit annoying if we have to buy 2 sets and only use 1 parental base, when we can easily make use of both.
Thanks in advance
