Sunamelon
Message 61 of 97
Re: BT video baby monitor 6000 additional camera
If you hold down the ok for afew seconds a small circle appears up on the left. That rotates between them every few seconds automatically. I found it by accident. I havent used it on the sound detection when watching both cameras yet.
Sunamelon
Message 62 of 97
Try ebay.
Loulaa
Message 63 of 97
Yes it’s still BT.
It seems to be the newest model, you can also access the camera from an app on your phone.
Rkazwini
Message 64 of 97
I have installed that app (think it's a great idea) but it doesn't seem to want to pair with my 6000 camera. Should it work? The app says to hold the link button until the camera beeps but it doesn't beep just makes the light flash...
Do you need to turn off the parent base unit to get it to work?
Loulaa
Message 65 of 97
Exactly the same issue I’m having!
Rkazwini
Message 66 of 97
So I had a reply from the app customer services and it seems the 6000 camera doesn't work with the app...has to be BT Smart Baby Monitor 2.8 or the BT Smart Baby Monitor 5.
Loulaa
Message 67 of 97
That’s disappointing as well as useless.
I’m guessing the 6000 camera won’t work with the bt smart monitor parent unit either?
Bacardi_queen
Message 68 of 97
Does anyone know if the parent unit on the 4000 will work on the 6000 camera? It looks identical to the 6000 parent unit but as the 4000 doesn’t have remote pan and tilt, I’m wondering if this functionality won’t be available?
Discom_ltd
Message 69 of 97
Hello Everyone,
For those who are looking for an additional camera or replacement cameras, you can contact ourselves at BT Spares Helpline on 0800 980 8999 or alternatively you can head to our website where you can place your order.
We also have replacement Parent Units and Power Supply Units available.
Regards,
Discount Communications Ltd
Andrewwray
Message 70 of 97
Can you provide a link to the spare camera on your store please, I cant seem to find it by searching. Thanks
