Jasperjmw26
Newbie
Message 1 of 3
BT virus protect
So at the moment i have Mcafee virus protection on a few devices and ive had it for about 2 years now. My plan is about to expire and noticed that BT has a virus protection programme powered by Mcafee. Bascially wondering how will it work with my current Mcafee account. Any chance my protection will just carry on for all my devices when i activate BT virus protection or will i need to install it on every device even though they used to have my other Mcafee accout on it?
Thanks for any help.
2 REPLIES 2
Moderator
Moderator
Message 2 of 3
Re: BT virus protect
Hi @Jasperjmw26,
Thank you for posting, it's good to see you back on the community.
If you have McAfee software installed, BT Virus Protect will replace it. You can find out more by take a look at If you already have security software
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”Kudos”
Jasperjmw26
Newbie
Message 3 of 3
That's great thanks!
