dave1776
Message 11 of 33
Re: BT webcam.
I can get into my account using Google search but cannot control anything from there. When I try to get into the account using the app with same username and password it tells me "error occurred"
Keith_Beddoe
Message 12 of 33
Re: BT webcam.
This is more likely to be a home hub issue where its run out of internal memory.
Try the usual fixes for the home hub, in this order.
factory reset the home hub.
http://bt.custhelp.com/app/answers/detail/a_id/11386/%7E/how-do-i-reset-my-bt-hub-to-its-factory-set...
Then turn Smart Setup off.
http://bt.custhelp.com/app/answers/detail/a_id/44328/~/switching-smart-setup-on-and-off-on-the-bt-ho...
dave1776
Message 13 of 33
Re: BT webcam.
Thank you....never tried that before..... do I just click your links or copy and paste.....will need to try it later once I take a brave tablet....and since I lost my wife a couple of years ago now have loads to do.
But I would really like to thank you for your time. Much appreciated.
Dave.
Keith_Beddoe
Message 14 of 33
Re: BT webcam.
The links take you to a couple of BT help pages, simply follow the instruction there.
It will restore the home hub to its default settings, so if you have changed the wireless name or password from the default, then you will need to change it back to your own preference.
Hopefully it will allow you camera and app to connect.
dave1776
Message 15 of 33
Re: BT webcam.
Don't think I have ever changed any password on it. Not that competent. Only password I know of is the one on the little plastic tag on the back of the router.
Keith_Beddoe
Message 16 of 33
Re: BT webcam.
Then it will be the same as that which is shown on the tag, so all wireless devices should simply reconnect.
Disabling smart setup is important, as smart setup can prevent some devices from working.
dave1776
Message 17 of 33
Re: BT webcam.
Even though it didn't seem to be a problem before?
Ok. At least I don't have to worry about password changes. So I will try to follow your links and the instructions. And hope I don't screw things up.
Hope to let you know that everything is working again.
Thank you.
dave1776
Message 18 of 33
Re: BT webcam.
Oh! Forgot to mention...I've got a laptop as well.
Can I carry out your processes from the lap top?
Probably feel a bit more confident doing that.
Keith_Beddoe
Message 19 of 33
Re: BT webcam.
It would best to do that from a laptop, as it will be easier to access the home hub web interface, as it may be awkward to do on a tablet screen.
dave1776
Message 20 of 33
Re: BT webcam.
Will do. Try to keep you up to speed as best I can.
