Akay47
Message 1 of 10
BT whole Home timed turn off led lights
is it possible to set the led lights to turn off and on at a certain time, as you can with internet access. I have a disc in a bedroom, which I'd like to switch off the led at night
9 REPLIES 9
BT Devices Expert
BT Devices Expert
Message 2 of 10
Re: BT whole Home timed turn off led lights
Hi @Akay47
It's not currently possible to do this.
I will share your feedback with the team for future development.
Community ModeratorDanO
Show your appreciation!
Kudos”
I am a BT Employee and an expert on BT Devices queries. I am here volunteering my own time to give advice, and help where I can with BT device queries. Go here for more info.
Message 3 of 10
A small piece of insulation tape works a treat Smiley Wink
BT Devices Expert
BT Devices Expert
Message 4 of 10
@gg30340
You'd just need a willing volunteer to put it on every night and take it off in the morning! Smiley Tongue
Kudos”
Message 5 of 10
@Dan-O wrote:
@gg30340
Do you really need to see the light during the day when you are probably not in the bedroom much?
BT Devices Expert
BT Devices Expert
Message 6 of 10
@gg30340 wrote:
@Dan-O wrote:
@gg30340
I guess not but assumed the OP would like to as they just need it to be off at night.
You can turn off the LED on all discs using the app/web interface.
Kudos”
Akay47
Message 7 of 10
Hi
I know I can manually turn the lights off with the app. It's helpful to be able to see the status of the discs in the daytime, but even on low brightness, I'd want to turn them off in the bedroom. It would save having to do this manually if I could set the times on and off in the app, like you can do for the "bedtime" setting. Perhaps one for the developers to consider!
Akay47
Message 8 of 10
thank you
stevemarsden
Message 9 of 10
I have the same issue. Another solution would be to provide a facility to adjust the LED's per disk.
BT Devices Expert
BT Devices Expert
Message 10 of 10
@Akay47 @stevemarsden
Thanks both for the feedback. We are continuing to review feedback to influence new features/enhancements so look out for changes in future app/firmware releases.
Dan-O
Kudos”
