Keegs999
Message 1 of 4
BT whole home firmware upgrade fails. App says no internet then bombs out
Have been having issues with slow performance but speed tests seem OK. Checked whole home and it stats firmware needs upgrading, suspect maybe wireless issue. Have gone into the whole home app, it tries to upgrade but says fails and then says no internet but there is. Have reset all devices but still no luck. Looked for the firmware online but can't find it, any ideas?
3 REPLIES 3
mattpartik
Message 2 of 4
Re: BT whole home firmware upgrade fails. App says no internet then bombs out
Archien74
Newbie
Message 3 of 4
I am having exactly the same problem.internet working fine.speed test 200mb v m ,although android box really slow.all other devices seem fine.but can't update firmware as app says no internet connection.tried switching everything off.no joy
Keegs999
Message 4 of 4
by way of an update, I have reset all devices, still no luck, download is good but performance of some devices poor. i checked out the link posted mattpartik which shows that maybe no update is due (?) however still having this performance issue all of a sudden for no reason.
